Civil points: Changing Label size when zooming in/out
Hello
For Civil points you can set the "Symbol size type" to "Relative to screen" and then the civil point symbol size changes when zooming in/out. Is there a way you can do the same for the civil point label? There is not a property such as "Symbol size type" for labels.
  • I think it should be a good feature, without changing the labels properties
  • Not sure if labels can be set to annotative then you could reset the Anno scale and the labels should change, not tested.
  • What do you mean with "Anno scale"? I did not find somewhere to tell Bricscad that the label will be annotative
  • As I said "Not sure if labels can be set to annotative" in bottom right down bottom you can change the annotative scale so if labels can be annotative then hopefully will change size. But it is not a auto thing.
