For example: drawing simple lines causes Briscad to hang
Version 6.2.6It's simple,open a (new) drawingDraw a line.Put entity snap settings on for endpoint, perpendicular, quadrant, insertion, center, midpoint, point, intersection (apparent).Draw a line:startpoint by using (typing on commandline) nearmake sure ortho is ontake a second pointBricscad hangs
No I can't reproduce that. Apart from a few imported Acad files I very rarely have a crash, I used to have some but now can't even remember how many revisions ago that was.Object Prperties toolbar caused some crashes previously and haven't been using it to know whether it is better now, though I believe that is fixed.Most of my troubles with Icad (and other software) in the past were caused by the constant checking of anti-virus software. Tried 3 or 4 brands before I twigged what was happening & turned it off.
0 -
This concerns a problem with the new SnapTrack feature, not with 'drawing simple lines'..It has been discussed in more detail on this forum in the topic named: 'Version 6.2.0006 Dimensioning'.Meanwhile we fixed this and are preparing an update release for the coming days.Thanks for your feedback.Hans De Backer
0 -
I tried but was unable to reproduce this problem.Could there be other settings that may have caused this problem?
0
