Installation and VBA
I have installed IntelliCAD with all the components.All the advanced menu options are available, but when I select Visual Basic Editor I get the message:"To run Visual Basic, you will have to install VBA6. Se readme for more details."I have tried to re-install and repair IntelliCAD, but the message still appears.How do I fix this?
0
We're encountering the same problem!Can someone help?
0 -
Perhaps you could try this procedure described in the knowledgebasehttp://www.bricsys.com/common/knowledge/topic.jsp?id=14
0
