Moving Paperspace entities to Modelspace
Is there any way to do this in Bricscad? In Autocad, if you wblock the paperspace entities to a file they will be written to modelspace in that file. In Bricscad they stay in paperspace. It's easy to insert modelspace entities in paperspace in Bricscad, but is there any way to do the opposite?
0
To copy / move entities from paperspace to modelspace use Ctrl C / X, then click the Model tab and press Ctrl V to paste the entities in model space.
0 -
THANK YOU! I hardly ever use Copy/Cut/Paste with BricsCad, but this works beautifully. Thanks again.
0
