Splines to Polylines
Can splines be converted to Polylines (arcs and lines) from within Intellicad. I've found a few tricks for autocad but they don't seem to work with Intellicad.Any help would be appreciatedThank youKim Watson
If there are just a few splines you can redraw manually with esnapp Nearest and Endpoint...
0 -
Thanks for the advice Ragnar.Unfortunately there are hundreds of objects each eith many splines.I did find a workaround though.The original drawings are created in Corel Draw.I then export the outlines into an autocad 14 dxf and use a prgram I found called SplineExplode from Techni-Soft GMBH to convert the dxf into polylines.When you then explode the result in Intellicad you get Arcs and lines. Perfect for CNC. Sometimes I have to tidy up a few radii but it's very accurate.
0
