v6 line weignts
We have recently upgraded to v6 from v4 and have created a CTB file to match our previous colors and lineweights. When we print, our device does not recognize the lineweights. This is the same plot device we used with the previous version. Question: Are lineweights, i.e. .010,.050, "different" in the new v6? Thanks.
I just carried on with the same ctb file I always used after it was originally created (can't remember when), no problems. Is it stored where Icad expects to find it?
0 -
Yes, the file can be found by Icad. The general problem appears to be the line weights stored in the ctb. It is as though Icad sees these weights as somewhat different than v4. In order to get a lineweight that even comes close to printing the same as v4, we have to significantly bump-up the line weight in the ctb.
0 -
Just a guess... could it have swapped mm's for inches (or vice versa) somewhere in its defaults?
0
