Load Application dialog box problem
When I use the "Load Application Files" dialog box to load a LISP routine, the name of the file is not visible.The dialog box displays the full path to the LISP file, so that the actual file name gets pushed off to the right. But, there is no horizontal scroll bar or ability to resize the box. So, the saved list of files becomes useless since all files display the same thing.Joe Dunfee
0
It might be a bit of a pain but you could make a new directory with a shorter path and copy them into it. Icad will load them from anywhere on your drive.
0 -
Thanks, that is a great work-around.Joe Dunfee
0
