raise the z-value of all drawing entities
hello everybody,is it possible to raise (or loweer) via vba the z-value aof all drawing entities or have i to run through all entities, check what kind of entity it is and change the value according to the kind of entity?thanks helmut
I've not tried this on Bricscad, only AutoCad, but you can select multiple entities then open the properties window and edit the Z coordinate value. I don't know how this will work on things like ACIS solids, or 3d polylines.You might use a selection filter to find the kinds of entities you want to change, or filter out the ones you don't.Joe Dunfee
0 -
I have writen applications roughly simular to this.The main problem you run into is that not all object have a z coordinate as such. A simple polyline (2d) has 2d points in the ucs it was created in. The points that define the line actualy have a z coodinate, but raining it does not raise the location of the line in the drawing (if you look at the properties of the line, the Z coordinate is grayed out).In my own program, I knew the orietation of such objects, and gererated a new drawing, with only true 2d objects, with points I calculated with the input of the entities in the original drawing.It is a lot of work, especialy if you want it to work with all entities.wat is your ultimate goal? in other words, what would you like the program to do?Regards,Huib.
0 -
Here is a LISP routine that can be helpful.;;;;;; Change of Z_value of entities by entering the difference in height.;;(Defun C:CHGOVA (/ dif e n ss gova gova1 gova$ gova1$ ly$ ly2 count ptss blss rec recnew x y z) (SetQ ly$ (cdr (assoc 8 (entget (car (entsel "\nPick a Text Layer to Modify...")))))) (Princ (Strcat "\nChanging Text on Layer * " ly$ " *" )) (SetQ ly2 (cdr (assoc 8 (entget (car (entsel "\nPick a Point Layer to Modify...")))))) (Princ (Strcat "\nChanging Hight of points on Layer * " ly2 " *" )) (Princ "\n!!! Changing Hight of all BLOCKs on all LAYERs !!!") (SetQ dif (GetReal "\nDifference [+/-]..: ")) (SetQ ss (ssGet "X" (list (cons '0 "text") (cons '8 ly$)))) (SetQ ptss (ssGet "X" (list (cons '0 "POINT") (cons '8 ly2)))) (SetQ blss (ssGet "X" (list (cons '0 "INSERT")))) (SetQ n -1 count (sslength ss)) (Repeat count (prompt ".") (SetQ e (EntGet (ssName ss (SetQ n (1+ n)))) ; n=„… gova$ (cdr (assoc 1 e)) gova1$ (substr gova$ (- (strlen gova$) 2) 3) ;…™‰‡ ˜…– ‰—‡ „…‚„ —…˜‰” gova1 (/ (Atof gova1$) 100) gova (Atof gova$) gova$ (Rtos (+ gova gova1 dif)) gova1$ (substr gova$ (- (strlen gova$) 1) 2) ;TXT -  ™ƒ‡ „…‚„ ‹˜„ gova$ (substr gova$ 1 (- (strlen gova$) 3)) gova$ (strcat gova$ " " gova1$) ) (EntMod (SetQ e (Modify e '1 gova$))) );;;;;;;;;;;;;;;;;;;;;; (SetQ n -1 count (sslength ptss)) (Repeat count (SetQ e (EntGet (ssName ptss (SetQ n (1+ n)))) rec (cdr (assoc 10 e)) x (car rec) y (cadr rec) z (+ (caddr rec) dif) recnew (list x y z) ) (EntMod (SetQ e (Modify e '10 recnew))) ) ;repeat (If blss (progn (SetQ n -1 count (sslength blss)) (Repeat count (prompt ".") (SetQ e (EntGet (ssName blss (SetQ n (1+ n)))) rec (cdr (assoc 10 e)) x (car rec) y (cadr rec) z (+ (caddr rec) dif) recnew (list x y z) ) (EntMod (SetQ e (Modify e '10 recnew))) ) ;repeat ) ) (Princ (Strcat "\nLayers: * " ly2 "," ly$ " * were changed, as well as all BLOCKS !" )) (terpri))(c:chgova)
0 -
If I'm understanding your question correctly, it seemsthat you just need to use the MOVE command...ie:MOVEALL0,0,00,0,z...z being the amount you want to change the z-values.
0 -
Exactly
0 -
the more interesting thing to do, and maybe the original request, was how to move a set of entities that are at different elevations - all to a certain z coordinate , not move them all by a deltaZ. can't seem to be able to edit it in the prop dialog like in acad, and a lisp i had (movetoz.lsp, protected) that worked in acad doesnt in bricscad. any ideas?
0 -
try thisflattenpick what you wantset z
0
