Block with bitmap??
Many companies have a bitmap as logo and therefore I would like to make a logo block contaling text and the bitmap.I cannot make a block with a bitmap picture (image) in BricsCad. I am not allowed to select the picture. Is it possible to do that in a way?
Welcome!
It looks like you're new here. Sign in or register to get started.
  • This works for me I can use both jpg and bmp.7.1.0010
  • You probably cannot select the image because the display of image frames is not on. You can turn the image frame on either by way of the menu or the command IEFRAME.I have just tested making a block with both an image and text and it worked for me (using V 6.2.0024.)
  • OK as long as I keep the file(s) on my own PC it works OK, but if I copy the dwg file to another computer, the picture is not displayed. Only a frame around where the picture should have been is visible.Is it possible to insert the complete picture into the drawing in stead of attaching it as a reference?Svend
Welcome!
