FONTALT
Does anyone know how to set FONTAL? I set it to simplex, simplex.shx, arial.ttf... It's all don't work.
  • I've found that the best way to integrate additional fonts into Bricscad is to acquire the specific alternative font files (I like Pan Roman and Technilight as an example) with their various extensions such as '.dwg, .pfb, .shx and .ttf' and copy them into your Bricscad -> Fonts directory.
Welcome!
It looks like you're new here. Sign in or register to get started.
