V8 Beta: Attributes in 0 layer
Attributes in the "0" layer are supposed to inherit the properties (color, linetype, etc.) of the layer in which the block is inserted. In several blocks where the attribute is in layer "0",the attribute is shown and plotted in the color of layer "0". In viewports where the inserted block layer is frozen in the current viewport, the attributes are shown but not plotted.
0
Yaacov,A fix for this matter has been made already. It will be available in our release.kind regards,Alexander Van Heuverzwyn,Bricsys
0 -
Thank you
0
