Renaming VBA Modules
I know that I can rename modules when I am using VBA in Excel. However, I don't seem to be able to do this with BricsCAD. It is starting to get difficult to remember which module is what. If I insert a new module, it is always the default name "Module1", etc. Is this a bug or a know limitation?Joe Dunfee
0
Choice "View" "Properties window" (or press F4).select a module you want to rename, and rename the module in the properties window.good luck.
0 -
Thanks, that is what I needed to know. (VBA in Excel behaves a bit differently. You can rename a module by just highlighting the module's name)Joe Dunfee
0
