Diameter Dimensioning
When using the Dimdia command it creates aleader type dim like Dimrad. Is there any othercommand to create a diameter dim with (2) endpoints like Acad? If not, maybe Bricsys will consider adding it to the wish list.
0
This is controlled by the Fit setting of the dimension style: instead of 'Best Fit' (default), use 'Text and Arrows'.Kind regards
0
