Linetype & Compatibility to AutoCad
I just started testing Bricsys and I have the version 1.8.19.I continued to work on a drawing in Bricsys and than I put it back to Autocad 2008 and strange effect occured with the lines: In Modelspace and Paperspace it doesn´t show the linestyles at all but If I go to the printpreview ist is OK... If I enter a Lintypefactor to see the lines properly it is not OK for printing... what can I do?The settings for the lines have been previously fixed in ACAD before I worked on it in bricsys
version 8.1.19...
0 -
to be even more precise: the Autocad has the Servicepack an the hotfix to display the lines...does anybody have an idea - I have helped myself in copying all elements into a new drawing, but that shouldn´t be the normal way...
0 -
Could you enter a Support Request for this and add a sample dwg?
0
