multi text funtion
How to change single text into a multi text function
0
I use a lisp called DTOM.lsp which is not one of my own. If you Google it you should be able to download it. It works well.
0 -
Now as you mention it ...Is there a function that works the other way round, i.e. converting mlinetext into single line text ?CheersJoerg
0 -
Yes, Explode does that.
0 -
That's a pleasant surprise, I'm sure it never used to in previous versions.
0
