Auto Load LISP programs
Can anyone help: I have two lisp programs that autoload by using a file "onstart.lisp" in the program file. When I start Bricscad 8.2.5 these programs autoload in to the first drawing that is opened. The second drawing that is opened will not have the programs loaded.
0
There are two startup lisps you can use which I can never remember the names of, but the one I use is On_doc_load.lsp. It loads with each file. You must be using the other one.There is a knowledgebase article on it and a thread here I think.Much simpler when it was just Icad.lsp, but I believe Icad has followed Acad's lead in adopting the new convention.
0 -
Bingo,, thanks for the help John.
0
