got an exception when I used sds_getstring in bricscad v8.1.19
in Other
Got an exception when I used sds_getstring in bricscad v8.1.19. Any help?0xC0150010: The activation context being deactivated is not active for the current thread of execution
0
Are you partying on another thread? If so you may need to use the sds_callinmainthread() function as the readme states. I have not been able to find any examples of how to use this though, maybe support can give us one :)hope this helps
0
