Always save to version 14DWG by default
We edit very simple 2D drawings before importing them to our CAM, and have been using software that saves in version 14 DWG. Now that we also use BricsCad, we would like to always save in that format too, by default. Does someone know if there is there an easy way to do it?TIA
0
Yes you can choose the save format. The SAVEFORMAT variable controls the default save format.In the SETTINGS menu choose SETTINGS, then type SAVEFORMAT in the search field. Choose the R14 format in the drop down list.
0 -
Thanks!!! :-)
0
