Insert from command prompt
I have been able to assign a button with the -insert command. I want the user to use the command line to enter the detail by name (which it will do), but once the correct detail has been entered by the user, I want to continue the command and automatically assign the default scale(1,1,0). The desired result would be to click the button, type in the detail number, choose a point on screen, and not have to have the user do any more input to the detail.I have tried virtually every combination I can think of to make this command work. (obviously, just not the correct combination) I am using version 8.2.6 build 10810. Is it possible to get the command to do what I am trying to do? Thanks in advance for your help.Larry Tennant
This works for me, using the same version:(command "-insert" pause pause "1" "1" "0")
0 -
Worked great! Thanks for the help!
0
