change block
Can someone explain me how to change a block. I have made a block and now I want to edit them.
0
In version 7 you can use the command Refedit, in V8 this feature is not yet supported, but if you search this forum for Refedit there was a post several months ago with programming code to edit blocks that we are using while the feature is again implemented in V8 and it works fine
0
