Offset and through point
in Other
First time use of command OFFSET with distance set as "Through point" does not work. New lines are created in the same distance which was set in this command before.When I type:
offset ENTER 1 2xENTER offset ENTER t ENTERnew entities are created in one unit distance not in selected position.
0
Yes, that's been true for a long time. I've been meaning to submit a bug report, via support request, but haven't gotten around to it yet.To work around the problem until it's fixed, you can just press Enter 3 more times before selecting the object to offset:1 to end the Offset command,2 to start it again,3 to accept Through as the distance.Then it works correctly. Do that anytime you use T as the distance (or you could omit it if you're sure you used T the last time).
0
