shift+ctrl+C - shift+ctrl+V
Hi everyoneI have a problem with these functions. If I use them, they work OK, but "paste as a block" is strange. It named new blocks from No.1 always. So if I have some blocks with this name in drawing, this command replace them. OK I can use : make a block and insert or past special and choose a name, but it takes twice more time. And next: if I want to edit this bloks named DWG+No. the are NOT stay on the position the are pasted.Don`t you know how to fix it? Or is it the BIG BUG in Brics cad?Thanks a lot forn an answare.
This indeed concerns a bug: the automatically generated names for the pasted blocks were not guaranteed to be unique. This problem has been fixed in Bricscad V9.2.7, which is scheduled to be released later this week. Kind regards.
0 -
Great :-)Thanks a lot
0
