STEP 3D
Does BricsCAD offer the possibility to create STEP 3D files?Thank youRainer Lothmann
There is no step export add-on but maybe you can use 3DM or another add-on...Here you go http://www.sycode.com/news/09_02_04.htm
0 -
Dear nurj son,this sycode plugin looks good.It does STEP and IGES import, but no export.Do you know, if they are planning to deliver export also?Thank you
0 -
Hi Rainer....I dont know about the planning of STEP export.But today you can use 3DM exporter.Today many cad software can read 3DM file directly.Here is the link : http://www.sycode.com/products/3dm_export_bc/index.htmGood Luck !!!
0 -
This is Deelip Menezes from SYCODE. We do hope to add support for STEP export sometime in the future. But not anytime soon.Deelip Menezes
0 -
Is there any option within Bricscad to export *.STEP, *.STP, *.STL or *.IGES files. I would like to export a mesh from Bricscad to AnsysAqwa. Unfortunaly at this moment a haven't figures out how to export a 3D mesh from bricscad to Ansysaqwa.
Daniel
0
