Should I stay away from the Utility Object?
Should I stay away from the Utility Object?(Jokingly: Yes, the Utility Object seems beyond my capacities...)The question is serious though: I struggled with the Object before () and ended up sending in two bug reports. Bricsys has confirmed these and fixes are already on their way. I am now programming my code in a copy of ACAD, as being the standard that Bricscad is modelled to, but also in ACAD I am faced the Utility Object behaving very peculiar and unexpectedly. I have developed a great dislike of it by now. Is the Utility Object known for its peculiar behaviour? Especially in relation to KeyWords? Is my suspicion correct that most developers do not use the Utility Object? That would also explain why I found these bugs, and not one of the Bricscad developers?Or should I go on trying? Is it all part of becoming a better programmer?
