Places bar
Is there any way to customize places bar in "Open Drawing" dialog?
  • Settings > Program Options > Files > File Dialogs > Drawings pathspecifies the fifth folder in the Places Bar for the "Open Drawing" dialog.The one below that, "Blocks path," specifies the same for the "Select Drawing" dialog that selects a file to insert as a block.Checking the box called "Use standard open file dialog," removes the Places Bar from the "Open Drawing" dialog. Because of the name, I thought it would make Bricscad use the Windows standard Places Bar instead of its own custom one, in which case we'd be able to customize all 5 Places. But it doesn't do that.So I created a folder just for shortcuts to the folders I'm using currently, and made that folder the fifth Place in Bricscad as well as in the Windows standard Places Bar.
