Real-Time Rotation and Shade
in Other
With command Real-Time Rotation 3D models rotate around world axes (true?). Is there any possibility rotate 3D model relative to view?
In versions 9.3.9 an 9.3.10 gouraud shade looking like flat shade. Is this bug or you going to improve shader and temporary turn off gouraud shade mode? Also, in shaded models, if you select one solid, many solids (not only selected) going to be transparent. This is (for sure) bug.
