modemacro
Hi!
How can I display diesel-expressions in the statusbar? Modemacro shows only the code "$(getvar,dwgname)", but not the result "Zeichnung1".
...no ideas?
At this moment, please use (command "_modemacro" <expression>) ... (setvar "modemacro" ...) does not yet work properly, but is under construction.
Also, not yet sure whether DIESEL is processed by command _modemacro.If you find a problem with DIESEL, please send a SupportRequest, so your request will not get lost.
Many greetings, Torsten Moses
