V10 Edit anomolies
Anyone else find extend on plines not functioning properly-as in doesn't happen? The offset command for circles results in a single node at the right hand quadrent and a centre point only, no line work.
  • The initial V10 release indeed had a problem when trying to GRIP_STRETCH  the last vertex of a non-closed polyline (I assume you don't refer to the 'extend' command but rather to using grip editing to extend the polyline?) This has been fixed in V10.1.7, released last Friday (to stay updated about new releases: on our website there's an RSS feed that does precisely this).
    Concerning the offset issue: I tried to offset a circle but this seemed to work fine. Could you please file a support request and add a short description off what our analysts should try to reproduce the problem? We will promptly look into the issue.
