Is it a bug or is it ACAD compatible?
Friday afternoon humor:
Sometimes one finds something so strange and unlogical that one wonders it it is a bug. Then one checks the Bricscad forum and the knowledge base to find very little.
Maybe one should send in a support request? But before you do, you check the discussion groups at Autodesk: Turns out to be a known limitation, for years...
And one knows it is not a bug: it is Autocad compatible...
Gerrit
Do you mean something like the mirroring of texts in blocks? You would think that could have been solved by now!
