Mr. Sid files
Is there any way to read Mr. Sid image files? The image files are a lot smaller when converted and stored with the .sid format. Map 5 will open these files, but Map 4 will not. This needs to be added if it can be.
  • Dear Mr. Bryan,I have a software to read *.sid files. I can forward you the same. However I require a filter/software which can convert jpeg, tiff etc file formats into sid files. Do you have one. please reply immediately without delay. Raghbindra
