INSERT bug again
When calling INSERT via (command "._insert" ...) from Lisp then Bricscad does nothing. This bug has been in previous versions of Bricscad, but it was OK in version 10.1.10, and it is here again with 10.2.5.
found the cause of the problem: BricsCAD changed the result from (getvar "acadver") from "17.0" to "17.1". Since I am writing code that runs on both AutoCAD and BricsCAD, I needed to switch to workarounds for some BricsCAD bugs, and I used the result of "acadver" for that. And now, when BricsCAD changed the result, my app could not switch to the workarounds and caused bugs.
BTW - I am using (command ":_insert" ....) as a workaround for (entmake '((0 . "INSERT")...)))) which does not work in BricsCAD as it does in AutoCAD.
Sorry, mixed it up with something else, that's
(setq @bcad (wcmatch (getvar "ACADVER") "*Bricscad*"))
Of course there is also the Bricscad-only system variable VERNUM.
I tried (getvar "_vernum") and I get "10.2.3 (UNICODE)", so okay
(dang, gotta upgrade to 10.2.6)
but I tried it in Autocad R14 (okay, laugh, that's what we're using, and why we're interested in bricscad)
and I get "S.0.79".
So you can't use it as a nil <-> T bollean indicator variable without too much parsing.
So I still suggest this lisp fragment to get "nil" if not Bricscad:
Yaakov: Thank you for that information. When I said "Bricscad-only" I was quoting the BC7-help...
FYI: In BC 7.1.0018 ACADVER is 15i0
