DOSLIB function reports 'Stack Overflow'
: (dos_getprogress "test" "do it" 5)
T
: (dos_getprogress -1)
-1
-1
-1
-1
-1
: (dos_getprogress t)
; ----- Error around expression -----
(AL_EXECUTEADSDEFUN DOS_GETPROGRESS REST)
; error : Unknown Error in Lisp or CAD system or 'Stack Overflow'
Works flawlessly in ACAD, but functions does seem to work in BC...
(acet-ui-progress-init "Working:" 10000)
(setq i 0)
(repeat 10000
(setq i (1+ i))
(acet-ui-progress-safe i)
(acet-ui-progress-done)i'll better use this then
I will check the issue ... many thanks for reporting !
thank YOU !
