DVIEW
In the absence of Architecturals that will run on V10, I'm trying to generate sections from 3-D models by using DVIEW. I know that sections can be drawn inside Bricscad but they are not dynamic and are 'regions' on layer 0.
In DVIEW I can set a target point and a camera position and set clipping and I get the section I want, Plan or Vertical Section, but even when I set Hide on elements which should be hidden are still visible.
Am I doing something wrong, or is the program 'faulty', or has somebody got a work-around?
Thanks in anticipation.
Ralph
