POP 0
When will we be able to customize POP 0 (zero) so that when we press the Shift+Right Mouse button in the middle of a command (TRANSPARENTLY) our custom tools such as Zoom and Pan can pop up instead of the ICAD ones.I know how to customize it for when I am not in the middle of a command but I need it to be customize when I use it transparently as well.Yes I use 0027.Regards to All Users!!
There i a workaround to this problem, in case you are not aware of it:You must configure a duplicate set of entries in the middle mouse button (POP 0) menu section, one for each item you want to have working transparently. Add them from the Customize dialog to the menu section Settings>Entity Snap.Once you have done that, export your menu as an .icm file. Open the .icm file in a text editor, locate the items you just added. Change Visibility=110toVisibility=1134for each item.Import the menu back to Intellicad.Hope this helps.
for shift rightclick during commands, you need to check the flag "temporary popup" in customise options.regards, sander
Thanks Guys. I got it working now!Best regards from Australia!
