Top view and Isojmetric view in the same viewport
Hi everybody
I have a little quiestion. In Autocad Sometimes I like to combine isometric details in a normal top view and I use a little procedure to do this. at the end I will have a top view and an isometric view in the same viewport,..... I put a viedo in:
http://www.youtube.com/watch?v=HhcIjucaxrI
to show how I do this and I explain here little by little in AUTOCAD, ok?
1. open any drawing, in this case a little house plan.
2. activate the isometric view.
3. copyclip all the plan.
4. go to Edit/paste special... select picture(metafile)
5. we have an image of the plan in isometric view, now cut this image.
6. go again to Edit/paste special... and select Autocad entity
7. BINGO! you have an isometric detail of the plan in the same viewport to edit like you wish.
I don't know if it is possible to do this in bricscad, I tried but I could not. If somebody can help me, I will appreciate it very much.
thanks a lot
jorge mora
