solids again
Is there anyone that can inform me if there is a way in which one can change the way in which INTELLICAD draws the SOLID command so that it mathes the same command in AUTOCAD?. Have you noticed that a "SOLID" drawn in AUTOCAD, comes criss-crossed in INTELLICAD?
