Filename length
I have some trouble in only one PC to save the drawings. I opened them with long names and when I try to save them the name become 8 characters long. Is there a setting inside IntelliCAD or is it a "Windows ME" compatibility problem?
  • I have noticed the same but under windows 2000. It seems to occur only if you open the drawing file by double clicking it. Try opening under Intellicad File open etc.I would assume that this is a Intellicad thing rather than a windows thing.
  • there is a system variable that controls filename length. Maybe that's the cause: check longfname.
  • I ran into this 8 character name problem when I had created an Access 2000 app and installed it on a ME machine. I did not have this problem with 95, 98, NT or W2000 so I think it is a ME problem and not Intellicad.
