extracting attributes (data)
Intellicad help defines template files for cdf or sdf output (attribute extract). I have gotten to the point where I no longer get error messages in the prompted process for extracting attribute data, however, the command bar indicates "0 records extracted". The icad help associated w/ the required template file shows the use of "BL:name", "BL:x", "BL:y", etc. to specify a block name and insertion points x and y. Help further states that there are 15 names (i.e. "BL") used to extract data, however, no mention of any other than "BL" in the example are given. There may be some associated settings that affect the lack of follow-through in the process for the program, though I don't know enough to know what a work-around might be. If anyone may have any successful experience w/ this process please respond. Thanksp.s. using win 98se and 2.2.0019; reasonably pleased w/ icad for drawing but wish to do much more.
  • I found these values in the code, and they are identical to what autocad supports:BL:NAMEBL:XBL:YBL:ZBL:HANDLEBL:LAYERBL:ORIENTBL:XSCALEBL:YSCALEBL:ZSCALEBL:XEXTRUDEBL:YEXTRUDEBL:ZEXTRUDEBL:NUMBERBL:LEVELregards, sander, Bricsnet
