Suddenly can't select anything
So I'm working along in Bricsnet ICAD 2000 2.2.0025 demo and suddenly I can't select anything. I can select just fine in other drawings but not the one where the problem started. I had just changed some settings in the Layer Explorer but I checked to make sure the layer was on and unlocked. Still nothing. I even opened the file on another PC, no good.Any Ideas?
  • I haven't had this problem but have had quirks on occasion. This is generally how I handle them:This post is to give a solution to what I have found works for many problems. When I have had problems with the plotting in a drawing or, say, the inability to set points with my civil add-on, I have found that if I copy the contents of my problem drawing (making sure to keep the base for each as 0,0,0) to a new base drawing that has been proven to work in all aspects. So far, this has always worked to solve the particular problems being delt with. Of course it is essential that the new base drawing is a good one.
  • (I removed some duplicate postings here)I'd be happy if you could send me a drawing, because i don't know the problem.The operation you mention can be simplified with all layers thawed , then doing a wblock with select all.Does "select all" work? Then there is a problem with window and picking selection.regards.sander
