New Version Question
When the new version comes out, what new additions will it have? And what will it have fixed?Also will it insert blocks with the "Z" Scale equal to the "X" & "Y" instead of having unequally scaled blocks. If you insert a block where you specify the scale and insertion point on the screen then it will not scale the "Z" equal to what you set the "X" & "Y". This is a real problem for my office. It worked fine in version 25 but it changed in 27.
