suppress error messages
Hello everyone,
I am looking for a way to suppress any kind of dialog or error message BricsCAD tries to send.
For dialogs this is quite easy, I just turned option "FILEDIA" off - is there something similar for error message - for example if I try to open a file named dwg, thats not really a dwg-file or a corruptet file.
Reason for that is, that I remote control BricsCAD via OLE in some applications - the user shall not see anything from BricsCAD, I will handle errors in my application. It's even worse for an application, where BricsCAD is running on another pc than the end-user-application - and everything is stuck with any kind of error message from BricsCAD itself.
