accoreconsole.exe for brisccad?
The dark side has the ability to run scripts and code typed on command line on drawings at a dos prompt.
Adesk did this to split the GUI stuff from base autocad core, to allow making gui portions for other os's's's.
Not that Bricscad needs this ability just to keep up with the Jones', but since it already runs on other os's is there something similar in its world?
I know how to open a dwg as dbx document, so that is editing without editor, and the bcad "realdwg" equivalent, but this dos promt way of running acad is unique, as you can do super simple things and not need to know com or .net api's.
thx
