plot stamp - vertical
I know how how to move the plot stamp around right, left or centered - but is there a way to turn it vertical. My main customer insists that the plotstamp be on the lower right corner vertical.
I would suggest you look into the "field" command.
I find it much more versatile and use it exclusively for my Plot Stamps.
Once set up with desired data & orientation, you can copy between drawings, viewports.
It'll even automatically update.0
