conflict of raster images
Hey, I reciently worked on a drawing with the latest ver 3.1 and found a conflict when more than one type of raster image is attached into the drawing i.e. crashing on a save. I later found that it works well for same file types only. Has anyone had a similar problem?Thanks,John
  • I attached several images of different formats and could save the drawing without problem.However, I did found out that *.tif files can only be attached on condition they are saved uncompressed or using the PACKBITS compression.
