Golden Nuggets on Translators
Golden Nuggets on Automatic Translators
Hello,
This is a break in the hard work for translating the new lines on BricsCAD V15. I'm using the Sisulizer manager, with access to Google and Microsoft translating engines.
At certain point I saw some precious pieces, and will share with you:
...Original line settings...
Original String:
To Tear off a Flyout Toolbar
Translated String (Auto translated):
A lágrima um menu desdobrável da barra de ferramentas
This phrase means something near: "a tear drops from a flyout menu...".
Another one:
Original String:
The 3D model updates dynamically when cycling the L-connection types.
O modelo 3D atualiza dinamicamente quando andar de bicicleta os tipos de conexão-L.
In this case you should ride your bike for finding good L-connections...
Another one:
Original String:
All faces lying in the plane of the selected plane are selected.
Todas as faces mentindo no plano do plano selecionado são selecionadas.
(lying -> liers...)
Supposedly the faces don't always tell the true...
Do you have any similar to illustrate?
