Word Doc issue
I just updated to 15.2 this morning. While working on a drawing I needed to make some adjustments to a table pasted in from Word. Typically I just double click the table, make the edits, save and close Word. Then after I regen the changes are there. The changes did not show up and I got the following response in the command line:
An error occurred while rendering entity 1DBC4: uninitialized object (0x80040007)
I ended up having to reinsert the table, but this error now seems to be part of the drawing. It is there whenever the file is loaded (even in v2014). Anyone else had this issue?
