BOLD.shx
I've been trying to plot a cover sheet using Bold.shx but the plot crashes. I'm using an HP 250C and I haven't had any trouble with the other text fonts I normally use. I can plot the drawing at half size and the Bold.shx font plots fine but at full size the only thing that plots is the border. The additional text drawn with other fonts don't plot either. If I change the Bold font to Simplex or some other font the cover sheet plots fine. The cover sheet is 24 x 36 inches. Is there something not compatible with Autocad's Bold.shx ?
  • Hi, I have been using the bold.shx since icad 98, and I am also using 250c. I don't seem to have the same problem nor can I recreat it. I am wondering if you are ploting in model or paper space?
