INSERT
I ve had some problems when I try to insert a drawing, I have 4 DXF files and I want to put all together, but it´s impossible, ICAD just lock.Please could someone help me??
  • Try converting the dxf drawings to dwg drawings, using the the conversion program at www.thedraftingshop.com and then inserting the drawings.
  • Hi, yesterday I tried to reproduce this issue and got the same results. I noticed that you could open a dxf and then save it as a dwg but you cannot insert a dxf. Anyhow thanks for the website, and was wondering if anyone has a routine to convert a dgn to dwg?John
  • With icad a dxf always needs a blanco drawing to start with(like acad 14).So you first need to open all dxfs separately in new drawings , and save as dwgs. Then start inserting.If that crashes , it's a bug and I'm interested.sander, bricsnet
