Images are dark/black when printing pdf. images are not in the right possition.
Hi
I have 2 problems:
Images are dark/black when printing pdf.(in autocad i don't have this problem)
Images in autocad position in the right place and in bricscad not.
anyone?
peace
Barak
Please file a support request and attach the drawing and the images. Use the eTransmit command to compose a zip file, which contains all files needed.0
how do I file a support request ?
when i try to file a support request i get a search in data base :
https://www.bricsys.com/nl_BE/support/
peace
Barak
Dear BarakOn the Support page, click on 'BricsCAD', and select 'Printing & Plotting' on the next screen. You then see a list of available topics about printing. If the problem you are facing is not in the list, click the 'New Support Request' button.Kind regards0
For black output I would start checking my pen settings.0
I had the same problem when using the Bluebeam PDF printer driver. I changed to the PDF -Xchange printer driver an the images print ok.So maybe try another PDF printer.Walter0
Please notice that PDF printers have a 'Black & White' option on the 'Paper/Quality' tab of the Properties dialog.0
Thank you,
i will try to use another pdf plotter.for my second problem i attach 2 phot's:
BricsCAD Platinum - [Melgeshof_Grondplannen_0V_140716.jpg0 -
this is how it comes in autocad
autocad image.jpg0 -
Hi Barak,
this is the user forum, intended for user-to-user communication.
If your intention is to report a problem to the development team, please file a support request and attach the files required to reproduce the issue.0 -
Hi Hans,
sorry but i don't know if it's a bug or something that i do wrong.
Well, if you file a support request we can investigate it and provide you with a solution...0
i will do
thanks
i found what was the problem with the dark images:
in the property window of the image in- MISC and then - Backround Transparency-it has to be on "NO"
peace
Barak
BricsCAD Platinum - [Melgeshof.jpg0
