Intellicad
I tried to change the directory of a polyline, but nothing happend. I need it for the order "measure". Can you help me?
  • tray just to give the comand measureclose to the side you whant to start as it start the measure from the close end point
  • Try instead to hit Tools-Inquiry-Area pick "find area of one entity" and touch your polyline.Viola the length is there.
  • Yes, you can do that to know the length of the entity. But there is also the MEASURE command, that places points or blocks on the enitity at a specified distance. The end closest to the point by which you identify the entity is the starting point for this 'measurement'.
